Dom U Posted June 9, 2015 Share Posted June 9, 2015 Hello guys. Well about a month of you some of you might remember I went through $#!& finding out why my truck kept dieing and narrowed it down to the ignition coil. Replaced ran great. Well now the problem is happening again so Wht would cause my ignition coil to short out so quickly? Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 10, 2015 Share Posted June 10, 2015 You didn't mention what year, engine, etc. you are talking about. Anyhow, I smoked two coils pretty quickly on my 91 when I first got it. The problem turned out to be a bad ground from the neg.battery terminal to the coil mounting stud. I ran a new AWG 8 wire from the coil mount to the neg battery terminal and haven't had any coil problems since. If just grounded by a mounting bolt to the block or elsewhere, a crusty or loose connection will create impedance and cause the coil to overheat and burn up fairly quickly. Link to comment Share on other sites More sharing options...
