oil pressure dropped, stalled out and then fuel pump quit
I just bought this 89 jeep comanche. Iran fine everything was good that I went to put a little bit of oil in it because the valve covers leaking gasket was leaking and I seen a little bit of milky oil in the rocker arm so I said oh no I've blown head gasket. so I check the oil no water on the dipstick. I'll pull one spark plug at a time to see if water comes out of the block as it turned over and that was a negative.put a new valve cover gasket on it, changed the oil, drove about 6 miles when I had a drop of oil pressure when I pulled up to a red light. I kept it going by having to keep my foot on the gas. It completely died out and the fuel pump quit entirely. Can someone please tell me what's going on?
