No turn, brake or hazard light problems?
91 Comanche 4.0. I have no turn, brake or hazard lamps. Did some diagnostics today and found that I don't have any power to the Hazard fuse terminal or the hazard flasher. There is power to the turn signal fuse terminal. Checked the hazard flasher for continuity and it is good. Has anyone run into this problem before? I'm also not quite sure if power goes from ignition to flasher to fuse box or the other way around? Can somebody offer some insight?
Much appreciated,
   Jack
This has turned up before. Make sure the turn signal, brake, and parking/tail light bulbs are correct in their front and rear housings, i.e. dual filament bulbs (2057 or compatible) and single filament bulbs (1156 or compatible) are all correct for their appropriate sockets. A single filament bulb in a dual filament socket, or vice-versa, can cause the symptoms you have.
