Juan Perez Posted May 27, 2007 Share Posted May 27, 2007 hey guys i have a 87 manche 4.0 2wd automatic and I'm in the market for a new set of wheels/rims. i found a set american eagle alloy 058's. they are 15x8, 5x4.5 bolt pattern and have 3.25 back spacing. my tires that I'm runnin with right now are 30x9.50 on stock wheels/rims. my question is will the new wheels fit ok on the tires and on the truck? any info will be appreciated. thanks :dunno: Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted May 27, 2007 Share Posted May 27, 2007 They will fit and clear everything, but that BS is not needed or required.... CW Link to comment Share on other sites More sharing options...
Eagle Posted May 28, 2007 Share Posted May 28, 2007 They will stick out beyond the flares, they will hit the flares if the suspension compresses, and if your state requires that the bodywark cover the entire tread portion of the tire -- it won't. Stock backspacing is 5-1/4" and 30x9.50s work great with that ... just slight rubbing on the lower control arms at full steering lock. You'll be pushing the tires a full 2" farther outboard. Link to comment Share on other sites More sharing options...
comanche-man22 Posted May 28, 2007 Share Posted May 28, 2007 ok sorry i have to steal the light for a sec...i have 32X10.5's if i were to go wider would i have problems? Link to comment Share on other sites More sharing options...
