Busy day
Finally had a nice day to get some projects done. I got my booster upgrade done. The spacer I made was a hard rubber piece and it was 4 1/2 inches square with a 2 1/2 inch hole in the center. The bolt holes were 3 7/16 on center if I remember correctly. The little oval plate is the block off for the clutch master. I bought a 2004 Grand Cherokee overflow bottle. I like the way it fits. I need to make a bracket for the bottom mount still. Oh, and all the gauges work correctly. The speedo is close but I will have to put a Garmin in to see how close. The battery hold down is not much but they are hard to find around here in good condition. It cleaned up good.
