Jeepjeff859 Posted January 29, 2015 Share Posted January 29, 2015 ok i have a 86 project and through hooking up a spark tester, determined there is no spark. what i know : just got a new exhaust manifold ( EGR hooked up ) ran before manifold was removed there is 12 volts constant through the coil and ignition module and to the distributor has all the correct wires going to it according to the wiring diagram. could it gave anything to do with the crank position sensor, it is looking a little gummed up? it also dumping fuel when trying to start. hooked it up to a snap on scanner and it said the coolant was -40 which is weird even with multiple heads we can't figure out how the distributor on the things work , the only wire going to it is the one from the coil, does it work off or grounding when it spins? any help would be great Link to comment Share on other sites More sharing options...
Dillithium Posted January 29, 2015 Share Posted January 29, 2015 Start here: http://comancheclub.com/topic/36382-cruisers-renix-tips/ Do the CPS test first, then post back. Link to comment Share on other sites More sharing options...
Jeepjeff859 Posted January 29, 2015 Author Share Posted January 29, 2015 Thanks I try all of it Link to comment Share on other sites More sharing options...
