feerocknok Posted May 23, 2007 Share Posted May 23, 2007 If one was to redefine the front end of an MJ/XJ and had the lens for the corner light, but didn't have the socket for the bulb that goes into the lens, would the socket from the old system fit in the new corner lights hole? I'm speaking of the one on the actual side of the vehicle, not the one next to the grill: If the old one will not work, does anyone know where to get ahold of the proper socket? Link to comment Share on other sites More sharing options...
mjcanoe Posted May 24, 2007 Share Posted May 24, 2007 feerocknok, Those sockects are interchangable w/newer models, sj's, cj's, yj's, even some gm units. they use a 194 bulb. you might even find new ones at a part store. mjcanoe Link to comment Share on other sites More sharing options...
feerocknok Posted May 24, 2007 Author Share Posted May 24, 2007 feerocknok, Those sockects are interchangable w/newer models, sj's, cj's, yj's, even some gm units. they use a 194 bulb. you might even find new ones at a part store. mjcanoe Thank you. That'll do it for me! Link to comment Share on other sites More sharing options...
