Olsen_brett Posted December 11, 2014 Share Posted December 11, 2014 thoughts Link to comment Share on other sites More sharing options...
Bonkers Posted December 12, 2014 Share Posted December 12, 2014 The first one looks to be a shift linkage not a transmission. The second seller seems awfully proud of their $#!&... but i have seen rebuilds offered at over $800 before so theyre not completely insane. The third one is ridiculous in my opinion - i just paid less than $600 for EVERYTHING from the bell to the Ujoint ends on a 98 ax15. Do some more research - pre 96 Ax15s can be had for as low as $150 and there are professional Kits available for less than $1k COMPLETE. Good luck! Link to comment Share on other sites More sharing options...
Olsen_brett Posted December 12, 2014 Author Share Posted December 12, 2014 Thanks for the reply. What do you think of this one? I can make the drive if it's worth it. http://houston.craigslist.org/pts/4777750311.html Out of a 94 cherokee 110k mi he says it shifts well. $300 Link to comment Share on other sites More sharing options...
Olsen_brett Posted December 16, 2014 Author Share Posted December 16, 2014 check Link to comment Share on other sites More sharing options...
kook911 Posted December 16, 2014 Share Posted December 16, 2014 These are some of the parts. t-case, front retainer bearing, new slave, master, bell housing, and cross member. I was going to go your route and try to piece everything together. Your best bet would to find a donor and pull it all off one jeep bc this will nickel and dime you to death. Link to comment Share on other sites More sharing options...
