Krome_Dome Posted November 16, 2014 Share Posted November 16, 2014 Alright guys, so I've already gone and replaced the clutch and have everything bolted back up. However, i can not depress my clutch now. I need to bleed the clutch correct? Also, I disconnected the battery and reconnected it after. The battery is reading 12.87v but I have no current going to anything. I've checked my fuses, and made sure there weren't any loose or disconnected grounding cables. Any ideas? Link to comment Share on other sites More sharing options...
sloride Posted November 17, 2014 Share Posted November 17, 2014 We need more info concerning your truck. Do you have the internal or external slave cylinder and that will depend on the type of transmission you have. Mine had the ba10 with the internal slave, swapped out to the ax15 with external slave. Link to comment Share on other sites More sharing options...
sloride Posted November 17, 2014 Share Posted November 17, 2014 To bleed the ax15 slave cylinder was just a matter of leaving the lid off the master cylinder and give the slave cylinder several pumps with the thumb prior to installing it. That's the way I did it, but I'm sure you can bolt it in and crawl out from under the truck to pump the peddle.. Link to comment Share on other sites More sharing options...
mikejenn2 Posted November 17, 2014 Share Posted November 17, 2014 Mine I just opened the slave bleeder and let it flow till I saw no air. I didn't have to pump it. Make sure to keep the mc full. Link to comment Share on other sites More sharing options...
Krome_Dome Posted November 17, 2014 Author Share Posted November 17, 2014 Thanks guys, we got it all taken care of. There was a grounding issue with the battery. As for the clutch, the forks werent lined up in the tranny properly. Thanks again. I'm just retarded. Lol Link to comment Share on other sites More sharing options...
