Transfer Case Shift Pattern
Because of the different shift pattern (and extra position), the shifter gate is different, and the tab that bolts to the transfer case that the linkage pops into is (going from memory) 3.5" on a 231, 3" on a 242.
Using the tab of a 231 on a 242 causes you to hit the end of the shift gate before you are fully engaged in 4-low.
As a good friend of mine always says: "Ask me how I know..."
