Project Motörcharge 2.0
Got some LED lights for Christmas.
All these are from the cab.
No lights.
H4 headlights.
Headlights and LEDs.
Difference is stupid lol
They'll be better when they're mounted on the winch bumper, but these are amazing at night on the farm and on the road to it. There's a $#!&load of deer around here and these should definitely help. Obviously won't use them on the main road.
And since I never posted the rear bumper. Still needs to be repainted, but it's ok enough til it warms up again. Steel was too cold and the primer/bedliner didn't adhere worth a crap when I painted it
BARELY got this thing done enough in time to get it out the shop and not catch hell on Monday for it tying up a bay. That said, it currently has no brakes, had to drive it like a boat lol
Just need new front lines. I've got em, just didn't have time to do them. Still need to align it and adjust everything. Everything so adjustable it's a pain in the @$$ and right now the steering stabilizer is loose because it was binding the steering and catching the tie rod for some reason. I guess I'll be doing some minor trimming as well. Popped the passenger side flare loose turning. I don't want to add more lift so I guess it's my only real option.
Killed me not being able to drive it home, but at least it looks badass for now. :laugh: Not sure when I'll be able to get to fixing everything else, but hopefully sometime this week.
Oh and another thing with the HC leaf springs. The damn centering pin hole wasn't even close to being big enough for the alignment pin. I had to take a die grinder to both springs to get them to rest on the plate correctly. I didn't just eyeball it either, I stuck a micrometer on it. Not the end of the world, but extremely annoying when I'm rushing to finish and I've got to take the leaf springs back out to grind out holes on leaf springs I spent almost $500 on. That said, I was afraid the back end was going to sit much higher than the front like stock but I think these will settle right about even with the front.
