1989 Eliminator Posted September 30, 2014 Share Posted September 30, 2014 There was a decent amount of oil coming from this hose and it comes from the top of the axle to the frame? Not sure what it does. Link to comment Share on other sites More sharing options...
thejim42 Posted September 30, 2014 Share Posted September 30, 2014 Its a breather/vent tube for the differential Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 30, 2014 Share Posted September 30, 2014 Your vent tube is probably stopped up and the oil is coming from the fitting where it connects to the axle. Take it off and clear the hose and fittings at each end so you can blow air through the assembly, then hook it up again. Are your axle seals leaking as well? Link to comment Share on other sites More sharing options...
1989 Eliminator Posted September 30, 2014 Author Share Posted September 30, 2014 No just this tube. Ill clean it out and see what that does. :thumbsup: Link to comment Share on other sites More sharing options...
