Needing to finally do the Slave Cylinder replacement, clutch has completely failed.
Thru Oreilly's I can get a complete kit (plate, disc, cylinder/bearing assembly), when looking up the part for the 6cyl/5spd and find one, and cross referencing it back around, it comes back as listed for the 4cyl/4spd.
My question is: is it the same stuff in the 4spd clutch as in the 5 spd clutch? Thanks in advance.
now going to surf the web with manufacturers part numbers to see what i can find out.
I did my homework...they are not the same between 4spd and 5spd...but for some reason the stores computer is back referenceing the listing as a 4cyl/4spd unit. Brand is Power Torque Clutch  kit# K-1675-22 and is correct for the 6cyl/5spd application.
The 2 trans use different diameter clutches and so on , so they are not a direct swap.  I really don't like "computer look-up" systems ...one little input error and confusion sets in !
