cruiser54 Posted September 1, 2014 Share Posted September 1, 2014 Connector Number Locations Connector C100: Left Of Master Cylinder On Dash Connector C101: Above Master Cylinder Connector C102: Behind LH Headlamp Connector C103: Next To RH Shock Tower Connector C104: Next To RH Shock Tower Connector C105: Behind Battery Connector C106: Next To RH Shock Tower Connector C107: Next To RH Shock Tower Connector C108: In Front Of Washer Bottle Connector C109: Next To RH Shock Tower Connector C110: RH Rear Of Rocker Cover Connector C111: RH Rear Of Rocker Cover Connector C112: RH Rear Of Rocker Cover Connector C113: RH Rear Of Rocker Cover Connector C114: RH Rear Of Rocker Cover Connector C115: Under Dash To Right Of Steering Column Connector C116: Above Master Cylinder Connector C117: In Front Of Washer Bottle Connector C118: Under LH Side Of I/P Behind Kick Panel Connector C119: Under LH Side Of I/P Behind Kick Panel Connector C120: Behind A/C Mode Select Switch Connector C121: Under LH Side Of I/P Behind Kick Panel Connector C122: Under RH Side Of I/P Behind Kick Panel Connector C123: Under RH Side Of I/P Behind Kick Panel Connector C124: Under LH Side Of I/P Behind Kick Panel Connector C125: Under LH Side Of I/P At Kick Panel Connector C126: Behind LH Rear Inner Fender Panel Connector C127: Behind LH Rear Inner Fender Panel Connector C128: Under RH Side Of I/P At Kick Panel Connector C129: Behind RH Kick Panel Connector C130: Under LH Side Of I/P At Kick Panel Connector C131: Under LH Side Of I/P At Kick Panel Connector C132: Under LH Side Of I/P At Kick Panel Connector C133: Under LH Side Of I/P At Kick Panel Connector C134: Under RH Side Of I/P At Kick Panel Connector C135: Under RH Side Of I/P At Kick Panel Connector C136: Under RH Side Of I/P At Kick Panel Connector C137: Under RH Side Of I/P At Kick Panel Connector C138: Under Front Seat Connector C139: LH Rear Inner Fender Panel Connector C140: Behind LH Rear Inner Fender Panel Connector C141: Behind LH Rear Inner Fender Panel Connector C142: Behind LH Rear Inner Fender Panel Connector C143: Behind LH Rear Inner Fender Panel Connector C144: Behind LH Rear Inner Fender Panel Connector C145: Behind LH Rear Inner Fender Panel Connector C146: Behind LH Rear Inner Fender Panel Connector C147: Behind RH Rear Inner Fender Panel Connector C148: In Console Connector C149: In LH Side Of Liftgate Connector C150: In LH Side Of Liftgate Connector C151: In LH Side Of Liftgate Connector C152: Behind A/C Mode Switch Connector C153: Near Cargo Lamp Connector C154: Above Transfer Case Connector C155: Behind RH Kick Panel Connector C156: Under I/P On Steering Column Connector C157: Below LH Side Of I/P Above Parking Brake Connector C158: Rear Center Of Cab Under Carpet Connector C159: Behind LH Rear Tail Lamp Assembly Connector C160: Behind LH Rear Inner Fender Panel Connector C161: At Rear Bumper Connector C162: At Rear Bumper Connector C168: Top Of Washer Bottle Connector C169: Below Washer Bottle Connector C170: LH Side Of Cowl Panel Grille Connector C171: To Left Of Steering Column Connector C172: In Driver's Seatbelt Buckle Connector C173: Under RH Front Seat Connector C174: Under LH Front Seat Connector C175: Behind RH Headlamp Connector C176: On Left Of Steering Column Connector C177: LH Side Of I/P Next To Light Switch Connector C178: LH Side Of I/P Next To Light Switch Connector C179: Behind RH Side Of I/P Connector C180: At Speaker Connector C181: At Speaker Connector C182: At Speaker Connector C183: At Speaker Connector C184: At Speaker Connector C185: At Speaker Connector C186: In Center Of I/P Connector C187: In Center Of I/P Connector C188: Below I/P Behind Defogger Relay Connector C189: In LH Side Of Console Connector C190: Under LH Side Of I/P At Kick Panel Connector C191: Under RH Side Of I/P At Kick Panel Connector C192: Taped To Harness Above Fuse Block Connector C193: Behind Center Of I/P Below Lighter Connector C194: On I/P To Right Of Steering Column Connector C195: Below Washer Bottle Connector C196: Center Of Liftgate Connector C197: Center Of Liftgate Connector C198: On I/P To Right Of Steering Column Connector C199: In Driver's Seatbelt Buckle Connector C200: Under I/P To Right Of Steering Column COMANCHE Connector C100: In LH Dash Panel Forward Of Fuse Panel Connector C101: Behind LH Headlamps Connector C103: RH Side Rear Of Engine Connector C108: Near A/C Compressor Connector C109 (Diesel Engine): Near Lower Center RH Inner Fender Panel Connector C109 (Gasoline Engine): Near A/C Compressor Connector C112: Behind Battery Near Starter Relay Connector C115: Taped To Engine Harness Behind Cruise Servo Connector C119: LH Side Of Engine Near Glow Plugs Connector C120: LH Side Of Engine Near Glow Plugs Connector C200: Under LH Side Of I/P Behind LH Kick Panel Connector C202: Under LH Side Of I/P Behind LH Kick Panel Connector C203: Under LH Side Of I/P Near Ignition Switch Connector C204: Behind Mode Select Switch Connector C205: Under RH Side Of I/P Behind Kick Panel Connector C207: Under I/P Above Brake Pedal On Steering Column Connector C209: Under RH Side Of I/P At Kick Panel Connector C210: Near RH Door Jamb Switch Connector C211: To Left Of Steering Column Connector C314: In RH Side Of Liftgate Connector C315: In LH Side Of Liftgate Connector C402: Under LH Side Of I/P At Kick Panel Connector C404: Under RH Side Of I/P At Kick Panel Link to comment Share on other sites More sharing options...
