ODB 1 trouble - check engine light on today
Took a long trip up to the high desert today (160 miles each way) to pick up a 4.2 long block.  On the way back home near Rainbow I noticed the "check engine" light come on.  It stayed on for the next 50 miles till I filled up the gas tank at Costco (22.65 gal and 400.1 miles).  When I restarted the car the light was gone and I made it home with out incident.
Just looked up this post in the DIY section:  Followed the procedure and I get a 51 code.  Most likely cause O2 sensor detects lean mixture check for vac. leak Now this was after 250 miles of 75-85 mph driving on a hot day.  So I will see if the problem happens again.
Now another small issue on the trip was the cold air stopped coming out the vents several times while I was trying to accelerate up a grade.  Is this normal?  Or am I loosing vacuum somewhere and the flapper valve moves to cut off the air flow?  As soon as I back off the throttle, the cold air flow returns to normal (till next time).
Taken together, do I have a vacuum leak I need to find?  What say you folks.
Thanks,
