Dando Posted August 2, 2014 Share Posted August 2, 2014 So I have a 95 parts XJ and I want to put the brake booster from it I to my 90mj to upgrade. I see that you must modify it slightly for the brake switch to properly work, could I avoid this by simply swapping the brake switch from the 95 also? Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 2, 2014 Share Posted August 2, 2014 Swap the 95 pedal assembly in with the brake switch and wire existing brake light leads to a NO set of contacts on the switch. Link to comment Share on other sites More sharing options...
Dando Posted August 2, 2014 Author Share Posted August 2, 2014 What is a "no set of contacts" Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 2, 2014 Share Posted August 2, 2014 NO = Normally Open. NO contacts close when you press the brake pedal to complete the brake light circuit. Link to comment Share on other sites More sharing options...
