teamsmith Posted July 14, 2014 Posted July 14, 2014 My '89 Pioneer restoration is nearly complete. It spent way too long at the frame shop getting pulled and then I had to get the rocker panels replaced: Using the good old boy network is cheap but slow. So now I need the following to finish it off: passenger door mirror: the one that has the adjustment stem that goes through the window passenger exterior window trim: the rubber is all cracked on mine gutter rail caps: the things that snap on the top of the rain gutters driver door threshold trim; that piece that screws on top of the rocker panel front wheel well splash liners, left and right: the rubber cowls that goes up in the wheel well to keep mud from getting into the engine compartment/header panel. Mine crumbled like black feta cheese when I removed it. I'm also gonna need a radio, or something, but that will come later.
Keyav8r Posted July 15, 2014 Posted July 15, 2014 Can't help you on the trim pieces but can advise you to go to the JY and pull inner fender liners from a 96XJ. I know the 96s will fit as I have them in my 88 MJ. Don't believe later model liners will fit, but could be wrong.
