1990 Comanche Build "little Big Truck"
I used JB Weld around the vents. Sand, clean and prep it real well. Should be fuel-safe.
I made a small disc the same size as the MJ sender, used the rubber o-ring from the MJ and put it in the hole. I've filled the tank to the top and it hasn't leaked with fuel against it.
The hold down tabs I made. The XJ's rubber ring is dropped into the hole and that too seals up great. I was super careful cutting the hole on top, it's as perfectly round as it could be.
Still to be tested is if I get any fuel starvation when climbing/leaning.
  • Replies 50
