I have 2 questions. I was hoping that some of you can help me out...
First, Will this be a problem if I run my tie rod on the arms with the holes not being straight across?
Second, I know that the bottom rod end goes to the passenger side knuckle and drag link, but does it matter where i connect the other ends? (for the drag link and other tie rod end)
Well, I figured out that the two middle ends are for the drag link and the top and bottom are for the tie rod. I forgot that two ends are left hand thread. They go on the passenger side.
as for the arms not being the same (the offset tie rod holes), I think it will be ok. If not, I will buy a new end and go crossover. The arms are different because I bought the last kit and the package was damaged in the mail and the driver side arm was lost. The seller replaced it at his expense...
