Ok the MJ didn't want to start at school this wednesday, so I had to pray to the jeep gods and fiddle with the harness connector before it finally started.
Today I finally rolled under the MJ to change it and found the job much easier than I expected it took about 5 min to remove the existing sensor and about 20 min to install the new one, all in all not to bad a job next time I will wait until the engine and tranny cool off a bit more.
I don't Know if I should keep the old one as spare though, it works most of the time.
I wouldn't. You can't trust it.
