Comanchemodder Posted May 10, 2014 Share Posted May 10, 2014 Hi guys, We are moving so I need to clean out the garage: 1) 1987 Comanche, 2.5L, AX-4, 2WD: * 160k miles, blue exterior, tan interior trim. daily driven. * swapped in a 1994 YJ 2.5L solid engine; doesnt burn a drop of oil. Still has RENIX. * No internal carpet; i ripped it out to stop some rust on the floorboards. Passenger side has some rust thru (see pic); * rest of the truck is rust free. * driver side door has slight dent and appears to have been bondo'ed by previous owner; also spont on tailgate which seems suspicous. * brand new heater core/evaporator core, AC Condensor coil. However remainder of AC is still in process (no hoses/compressor yet). * Kelly's work in process wiring kit. * Electric fan * Current TX tabs and passing safety inspection. The extra's (included): * AX-5 4x4 transmission * Dana 44 Front from wagonner; disassembled with intent to rebuild; but not there yet. all part there. * AMC-20 from rear of same wagonner; one-piece axles (the strong version). * Driver side door from '96+ XJ - includes door striker. * 1994 MPI system - ECU, manifold, distributor, FW, wiring harness. * brand new track bar waiting to be installed. * couple extra tie rod ends. * Bunch of other small extras: starter, alternator, brakets, aluminum manifold, etc. * Dana 300 (cause its cool). Specific pictures of any item available upon request. Link to comment Share on other sites More sharing options...
Comanchemodder Posted August 12, 2015 Author Share Posted August 12, 2015 Bump Link to comment Share on other sites More sharing options...
TheDirtyJeep401 Posted August 19, 2015 Share Posted August 19, 2015 I Pm'd You. Link to comment Share on other sites More sharing options...
Archived
