Stripped Brake Line
guys, I put brakes on the manche today including calipers and hoses. I rounded the DRIVERS side nut on the hard line where it connects to the hydraulic line. I even used a flare wrench. now I have everything new except this ratty hose and I can't get it undone from the hard line. what's my options? is there enough room to get a wrench under the fitting block where it leads into the mc or will I have to remove everything to gain access from the top. don't know if I can get my hands up in there from the bottom cause of the front shaft. is there a plug and play brake line for the system or will I have to bend myself?
I had the same problem with my hardline on the drivers side! I can't imagine that's a coincidence. Anyway, what I did.
- Lots of penetrating fluid, spray it, go play fetch with the dog for 10 minutes, reapply, etc. Rinse and repeat.
- Find your favorite vise grip, preferably one with teeth.
- Use a heatgun/blowdryer to make it warm, DO NOT use an open flame/torch
Then use the vise grip to break it loose, make sure it's on there good before you start to break it loose.
I hope for your sake the nutsert on the frame isn't loose, or comes lose when you start applying pressure. That's a different problem I had to tackle.
Good luck!
but how hard is it to replace that brake line? or should I just take her to a brake shop? they should have the nutsert thingy and the line but how much labor time????????? don't wana spend a deuce or so for a lousy brake line. the thing that makes it double hard for me is that I have partial amputations on BOTH thumbs. hard to work in tight places with small fittings.
