stoney Posted March 30, 2014 Share Posted March 30, 2014 I know there used to be a video on this subject, but haven't found it, is it still in MJ Tech? Link to comment Share on other sites More sharing options...
91Pioneer Posted March 31, 2014 Share Posted March 31, 2014 The video isn't terribly helpful. Pull the window crank handle straight off, unscrew the 3 screws on the door handle, the 2 screws on the handle, rotate it 90 degrees (up) to remove if it's the "hockey stick" type. Then use a tool to pop the clips off the back side of the panel, on the front, back, and bottom and pull the panel up and away, off. You don't even need to remove the door handle clips, just fit it through the panel when pulling it off. Link to comment Share on other sites More sharing options...
92tanMJ Posted March 31, 2014 Share Posted March 31, 2014 The video isn't terribly helpful. Pull the window crank handle straight off, unscrew the 3 screws on the door handle, the 2 screws on the handle, rotate it 90 degrees (up) to remove if it's the "hockey stick" type. Then use a tool to pop the clips off the back side of the panel, on the front, back, and bottom and pull the panel up and away, off. You don't even need to remove the door handle clips, just fit it through the panel when pulling it off. :agree: Yep that's how I did it. It's pretty straight forward when you do it....one of those you just jump right in and do. There really is nothing to it. :thumbsup: Link to comment Share on other sites More sharing options...
danbyrambler Posted March 31, 2014 Share Posted March 31, 2014 Here t'is http://comancheclub.com/topic/42336-removing-door-panels/ :thumbsup: Link to comment Share on other sites More sharing options...
