Hillcountrymac Posted March 9, 2014 Share Posted March 9, 2014 I have another question.If I upgrade the gauge cluster from base, what will plug and play for a 90? Will Cherokee fit from same years?There seem to more of those. Thanks Link to comment Share on other sites More sharing options...
jimoshel Posted March 9, 2014 Share Posted March 9, 2014 I just completed this swap. 1990 MJ, 4.0. I used a '88 panel from a XJ. Replaced the oil and temp sender units. Works great. Tach right on. Any thing from a '87 thru '90 will work. Also swapped the speedo to keep the mileage straight. Link to comment Share on other sites More sharing options...
Hillcountrymac Posted March 9, 2014 Author Share Posted March 9, 2014 I just completed this swap. 1990 MJ, 4.0. I used a '88 panel from a XJ. Replaced the oil and temp sender units. Works great. Tach right on. Any thing from a '87 thru '90 will work. Also swapped the speedo to keep the mileage straight. By anything you mean Cherokee also? Link to comment Share on other sites More sharing options...
jimoshel Posted March 9, 2014 Share Posted March 9, 2014 Yes. From the dash forward, XJ and MJ is identical. XJ= Cherokee MJ=Comanche Link to comment Share on other sites More sharing options...
Hillcountrymac Posted March 9, 2014 Author Share Posted March 9, 2014 Thanks I'll get to lookin Link to comment Share on other sites More sharing options...
