88MJay Posted April 25, 2007 Share Posted April 25, 2007 I can make mine look just like the one in the above pic. I have about 10 lbs. of pressure in my 35" Krawlers on 8" rims. I would have thought something was seriously wrong but I've been down this road quite a few times and knew it was due to my increased caster (10 degrees) and the toe being out. Well... that and you can see that it's all tire and the rim is still square with the axle. Any updates? Link to comment Share on other sites More sharing options...
CEThomas Posted April 26, 2007 Author Share Posted April 26, 2007 It must be an optical illusion of the tires :nuts: Here are photos of both rims at 0 degs. Here is what I see :eek: Here is caster with the wheel turned all the way left on the drivers side. Here is caster with wheel stright ahead on drivers side. Charles Link to comment Share on other sites More sharing options...
88MJay Posted April 26, 2007 Share Posted April 26, 2007 Ya... see how they lean one way and then the other in the above pics... re-check the toe and set it to 0 degrees, put the proper air pressure in the tires and see if it doesn't go away. Link to comment Share on other sites More sharing options...
CEThomas Posted April 26, 2007 Author Share Posted April 26, 2007 Will give it a try this weekend :cheers: Thanks, Charles Link to comment Share on other sites More sharing options...
