Mathias Posted February 17, 2014 Share Posted February 17, 2014 This morning i went out to go through the MJ I just bought. Stuck the key in the passenger door and discovered it sticks and is very hard to turn. After looking close, it appears as if something forgien was used on both sides, damaging the locks. I was wonder if anybody has changed the door looks before and if i can use the set out of a 93 Cherokee? Neither the Cherokee nor the MJ have electric locks but I don't want to start taking things apart unless i have a replacement for it first. Link to comment Share on other sites More sharing options...
Rockfrog Posted February 17, 2014 Share Posted February 17, 2014 Assuming this is for your 89 you mentioned elsewhere ... I changed mine a few months back ... PO had broken a key off in the driverside door. Picked up a set (omix-ada) and swapped them in in a couple hours. The locks in a 93 have a larger opening in the door and won't work. Link to comment Share on other sites More sharing options...
Mathias Posted February 17, 2014 Author Share Posted February 17, 2014 Duh, you sir are correct. I didn't even bother looking at the key opening on the donor to see if it even matched up. Thanks for the reply. Link to comment Share on other sites More sharing options...
