airspeed Posted February 6, 2014 Share Posted February 6, 2014 Working on my sons 96 XJ we replaced the battery and noticed a little spring loaded sensor in the bottom of the tray. When you lift the battery up the sensor pops up at a 45 degree angle? The sensor has two wires and a connector on it. I should have taken a picture... Any body know what this is? Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted February 6, 2014 Share Posted February 6, 2014 To the best of my knowledge, it's there to measure the temperature of the battery to control charging rates. Just as an add on, what the Jeep manual says:The BTS is used to determine the battery temperatureand control battery charging rate. This temperaturedata, along with data from monitored linevoltage, is used by the PCM to vary the batterycharging rate. System voltage will be higher at coldertemperatures and is gradually reduced at warmertemperatures.The PCM sends 5 volts to the sensor and isgrounded through the sensor return line. As temperatureincreases, resistance in the sensor decreasesand the detection voltage at the PCM increases.The BTS is also used for OBD II diagnostics. Certainfaults and OBD II monitors are either enabledor disabled, depending upon BTS input (for example,disable purge and enable Leak Detection Pump(LDP) and O2 sensor heater tests). Most OBD IImonitors are disabled below 20 degrees F Link to comment Share on other sites More sharing options...
airspeed Posted February 6, 2014 Author Share Posted February 6, 2014 That could be it... It is a nice flat surfaced sensor about the size of a 50 cent piece, two wires going in the bottom. Link to comment Share on other sites More sharing options...
