RavenMocker Posted January 31, 2014 Share Posted January 31, 2014 Ive read up on a lot of different ways to do this but now I just want to hear what others have to say. I am converting my MJ to a Cummins 6AT 3.4. I am going to tune the engine to get the nearest I can on both power and fuel economy. But I can't decide what transfer case to go with. So I would be looking in the neighborhood of 140-175 hp and 250-300 lb-ft. My build thread has more basics about the engine being used. I like the idea of having AWD but if I am able to shift into a 2x4 mod that would be nice. I'm still figuring out what transmission to use, maybe an NV3500-4500 or a hybrid Jeep/Toyota transmission and tease. The Cummins has a chevy bell housing on it. Also I had thought I would need to covert to a front axle with the pumpkin on the passengers side between the turbo and exhaust are on the drivers side. But if I have the room I might pipe it under the engine like it currently is on the stock motor. Just don't know how a three inch pipe is going to fit. So I could use some advice on what way to go here. The biggest tire I intend to use would be a 33" but I liked using 235/85R16's and might just stay with those. The cummins fits in the engine bay so I won't need to worry about clearances as you would with a 6BT. The truck is intended as a daily driver, weekend warrior, lite towing and hauling stuff. Link to comment Share on other sites More sharing options...
benjy_26 Posted February 1, 2014 Share Posted February 1, 2014 If it's a Chebby pattern, I'd make my life easy and install a 4L80E and a Chevy passenger side t-case(NP205 would be awesome). Add a D44HD in the front and a semi-floating 14 bolt in the rear and you get a durable, cheap to maintain drive train. The full width axles might be tricky to adapt to a MJ and would look a bit weird, though. Link to comment Share on other sites More sharing options...
RavenMocker Posted February 2, 2014 Author Share Posted February 2, 2014 If it's a Chebby pattern, I'd make my life easy and install a 4L80E and a Chevy passenger side t-case(NP205 would be awesome). Add a D44HD in the front and a semi-floating 14 bolt in the rear and you get a durable, cheap to maintain drive train. The full width axles might be tricky to adapt to a MJ and would look a bit weird, though. If I go the 4L80E route then I need to run either a controller or set it up to run manually. I think a 700R4 would work better. I will look into the axles and the NP205. Link to comment Share on other sites More sharing options...
mvusse Posted February 2, 2014 Share Posted February 2, 2014 The power numbers you listed don't warrant a 4L80E. I would go with the 700R4. Link to comment Share on other sites More sharing options...
MJ_Milam Posted February 2, 2014 Share Posted February 2, 2014 I would go with a 4L80 over the 700R4/4L60. not a fan of the 700. Stand-alone harnesses are easy to come by these days. And I wouldn't touch a semi-floating 14-bolt. Go full floting corprate 14-bolt. cheap and easy to find. An 8-lug 44 should be plenty strong for what you're building. If you're wanting an on-the-fly 2 to 4wd you'd probably better off with an NP 208 or NP 241 Link to comment Share on other sites More sharing options...
benjy_26 Posted February 2, 2014 Share Posted February 2, 2014 FF 14 is MUCH stronger, I agree. The SF can handle quite a bit of punishment, though. I only mentioned the SF due to thw tire size he plans on using. I have 37's on my K5 with a healthy 400 SB and the SF14 has no issues with that set up. I think he'd be dragging the hell out of that FF14 with tires that small. Link to comment Share on other sites More sharing options...
benjy_26 Posted February 2, 2014 Share Posted February 2, 2014 A 700R4 from 87 onwards is rated at 450ft-lbs. That's assuming it's in brand new condition, pulling small-ish tires, and not seeing any abuse (towing, off roading, racing). Also, keep in mind that auto trannys develop their holding power through fluid pressure. If he's getting 300ft-lbs at 1000 rpm, the 700R4 might not have enough pressure on the clutches to holdbup to the torque. I still say 4L80E. Get a stand aline for the tranny, or, if you want to be bulletfproof and don't need overdrive, a THM400 or SM420 would be the way to go. Link to comment Share on other sites More sharing options...
RavenMocker Posted February 3, 2014 Author Share Posted February 3, 2014 I could go with a TH400 and then swap over at a later date when I am better set up for it fundage wise. Link to comment Share on other sites More sharing options...
RavenMocker Posted February 3, 2014 Author Share Posted February 3, 2014 What about a Dana 20 behind an TH400? Link to comment Share on other sites More sharing options...
benjy_26 Posted February 3, 2014 Share Posted February 3, 2014 As far strength and size goes, the Dana 20 is a fantastic case.IIRC, Jeep used them in a lot of FSJ's up to and including the J4000 trucks. The low rangr is only 2:1, but if you're not rock crawling, it should'nt be a problem. You may have to mod thr TH400's output shaft to get the two units to mate. I'm not to clear on the details. I had a T18/D20 combo for a long time in a J10 with a 4.2, and it was great. Small, light, and tough. Link to comment Share on other sites More sharing options...
RavenMocker Posted February 4, 2014 Author Share Posted February 4, 2014 As far strength and size goes, the Dana 20 is a fantastic case.IIRC, Jeep used them in a lot of FSJ's up to and including the J4000 trucks. The low rangr is only 2:1, but if you're not rock crawling, it should'nt be a problem. You may have to mod thr TH400's output shaft to get the two units to mate. I'm not to clear on the details. I had a T18/D20 combo for a long time in a J10 with a 4.2, and it was great. Small, light, and tough. I have access to an adapter plate with gear that mates a Chevy TH400 and the Dana 20. Link to comment Share on other sites More sharing options...
benjy_26 Posted February 4, 2014 Share Posted February 4, 2014 Sounds like you're set! Keep us posted. Link to comment Share on other sites More sharing options...
benjy_26 Posted February 4, 2014 Share Posted February 4, 2014 Just lept into my mind.... When I swapped from the T18/D20 combo in the J10, I threw in a THM400/NP205 combo out of a CUCV. It works well, but I did notice that my rear driveshaft is oh-so-slightly angled to the passanger side from the rear output of the 205. This leads me to believe that the Dana 20 has a slight offset. I have had ZERO issues with tuis set up. No broken joints or binding and I have plenty of travel. I just thought I'd mention it in case your TH400/20 combo causes your driveshaft to angle out. Link to comment Share on other sites More sharing options...
RavenMocker Posted February 5, 2014 Author Share Posted February 5, 2014 Just lept into my mind.... When I swapped from the T18/D20 combo in the J10, I threw in a THM400/NP205 combo out of a CUCV. It works well, but I did notice that my rear driveshaft is oh-so-slightly angled to the passanger side from the rear output of the 205. This leads me to believe that the Dana 20 has a slight offset. I have had ZERO issues with tuis set up. No broken joints or binding and I have plenty of travel. I just thought I'd mention it in case your TH400/20 combo causes your driveshaft to angle out. Thanks.... If I had gone with one of my other choices Id be using FZJ80 front and rear axles with factory lockers. Then it would really be offset to the passengers side. :) Link to comment Share on other sites More sharing options...
