Can A 2Wd Ba-10 5Spd Easily Be Converted To 4Wd?
They aren't the best 4.0L transmissions...
but, yes, they are VERY easy to convert from 2wd to 4wd
if you have the 4 wd output housing from a broken BA
The output shaft on 2wd versions is splined all the way to beyond the speedo drive.
unbolt the 2wd tailshaft
mock up a 4wd tailhousing to get the proper shaft length marked
cut the shaft
bolt on 4wd tailhousing
=instant 4wd trans
I realize the ba-10 is not the best ,but mine at least for now is fine ,shifts buttery smooth at 183k. Just thought that it might be cost effective for me to pick another up if I could convert it to 4wd. Thank you for the information Jim I may just go and get the trans. for a relatively easy repair if and when I need it.
