What Size Bolts Go In The Back Of My Power Steering?
I bought an 88 jeep comanche 4.0l inline 6. I have been rebuilding the engine and somewhere along the way I have lost the bolts in the back of my power steering pump. If anyone knows of the right size bolts so I don't have to take it back off that would be amazing!
I also have my engine out of my Comanche and I happened to be smart enough to put the bolts back in the holes I took them from thank god but there are two bolts that hold the pump to the bracket  I'm almost positive there 13 mm but I just used a 9/16 to get this one out (its was already loose and the socket doest fit too awfully snug but the bolts are two inches long (both of them from head to tip ) and both have washers that don't come off (there pressed on or whatever and the threaded part of the screw appears to be 5/16 wide with a tape measure  but I'm sure what the thread pattern is exactly hope this helps and let me know if you need to know anymore bolt sizes I'm pretty much back at the same step as you reassembling
