Md Juan Products
elmerjeeper011
I put an MD Juan body tub on my Ford GPW. it is a script tub just like my original. Here's whats good:
1. The owner of MD Juan is constantly changing and correcting his products. He is very active on G503.com
2. It has the look of a fresh brand new jeep when you use his tub.
3. The parts generally have very good attention to detail
4. One of the only sources in the game. Pretty much makes everything for everybody else. including omix ada
The bad:
1. the primer on his stuff is worthless.
2. everything is just slightly off. just fractions of inches off.(like my brake pedal holes being wrong)
3. tubs can be very hard to put on frames. like to the point some people have thrown away a brand new tub. (mine personally fit like a glove with just a little frustration.)
4. can be expensive
5. ford marked parts on GPWs usually aren't the right F mark.
all in all if you have a good frame and powertrain and a bad body you won't go wrong with MD Juan. 541043_10150666707652568_930810417_n.jpg
