jmderyke Posted September 14, 2013 Share Posted September 14, 2013 1986 4x4 2.5 dana 35 spring under I was given a rubicon express 4.5" xj lift with springs, upper and lower control arms and extended brake lines, I was told the springs settled to 4". To finsih my truck I wanted to put an add a leaf on the rear of about 3" since it sits about a inch higher in the rear it should balance out? The only company I can find for 3" for the mj is rustys offroad any others? Link to comment Share on other sites More sharing options...
nitroxsteve Posted September 15, 2013 Share Posted September 15, 2013 My rustys 3"AAL only gave me about 1.5" of lift. But with the 3" front springs its still an inch higher in the rear so it sits nice. Each truck is different but I doubt you will see a full 3" with the rustys AAL. I don't have any experience with any other brands. Link to comment Share on other sites More sharing options...
500kalle Posted September 15, 2013 Share Posted September 15, 2013 Try to add 2 wrangler CJ leafs each side!! It'll flex smooth and bring you a Lift bout 4-5 Inches!!! If you want more Lift, you should Take some IRONMAN shackles!! I did so and I'm very glad with The result!!! Link to comment Share on other sites More sharing options...
500kalle Posted September 15, 2013 Share Posted September 15, 2013 Link to comment Share on other sites More sharing options...
500kalle Posted September 15, 2013 Share Posted September 15, 2013 Now running 31x10,5-15 on 8x15 rims!! Link to comment Share on other sites More sharing options...
92tanMJ Posted September 15, 2013 Share Posted September 15, 2013 Like what said above the rustys 3"AAL is for an xj (even thought it says mj) so it only gives about 1.5" of lift. But if you put on a 2" shackle you should be good and right around the lift hight you want to be. Link to comment Share on other sites More sharing options...
jmderyke Posted September 16, 2013 Author Share Posted September 16, 2013 Thanks for the help! I may do a trial and error route of adding a couple leafs. I use my truck more for fire wood and camping hardly any wheeling. Link to comment Share on other sites More sharing options...
92tanMJ Posted September 16, 2013 Share Posted September 16, 2013 If you do, do the trial and error route let us know what leafs you used. Genernally you want leafs with more arch. For example, MJ leafs can lift an XJ but XJ leafs won't lift an MJ. I used S10 leafs in my XJ bastard pack. I'm not sure if s10 leafs will work for an MJ though Link to comment Share on other sites More sharing options...
92tanMJ Posted September 16, 2013 Share Posted September 16, 2013 You could always go spung over and then use a stock xj shackle? That might still be too tall for you though Link to comment Share on other sites More sharing options...
jmderyke Posted September 17, 2013 Author Share Posted September 17, 2013 I do have a Dana 44 on my parts Cherokee and if I put that in it would prob b the perfect height but I wouldn't increase the amount of weight I can carry. I have some home work to do... will most likely do what 500kalle did it looks good.. I will keep ya posted Link to comment Share on other sites More sharing options...
