Tigger Posted September 11, 2013 Posted September 11, 2013 SOLD Front Dana 30 Axle out of 97 Cherokee Non Vacuum Disconnect New wheel bearings Calipers and pads Rotors Brake Hoses U-Joints Rear Axle Dana 44 New brake shoes New drums New bearing New wheel cylinders and hardware New parking brake cable New brake lines Changed to a closed cooling system Rancho shocks Water pump Serp belt Oil pressure sending unit Spark plugs Rear main seal Oil pan gasket New clutch New slave cylinder New clutch master cylinder AX-15 Tranny rebuilt about 5000 miles ago used Redline MTL Rubicon express front long arm kit suspension Rear spring over axle kit with custom spring packs New ignition switch Rear bumper 33x12.50 R15 Pro Comp Xterra Tires on American racing aluminum rims It does need a couple things but it is my daily driver. Runs great and has no rust in the Cab. Please text or call 775-2two0-9eight21 Thanks Steve
Crash Posted September 24, 2013 Posted September 24, 2013 Payments? haha. Always wanted those wheels. I like the AR-23's better meow, but still dig those. Internal or ext. slave on the AX-15? Also, Long arms.. y-link or 4 link
Archived
