drase Posted August 19, 2013 Share Posted August 19, 2013 My passenger door check somehow moved back into door and is stuck. Only about 1 inch is still out. I tried to pull it out, put my hand in door to push it out and it won't budge. I also tried to angle it to push it forward. How do I get it out? Link to comment Share on other sites More sharing options...
jimoshel Posted August 19, 2013 Share Posted August 19, 2013 Place a steel rod, or small screw driver in the pin hole. Something to work with. Then get a claw hammer or crow bar. prying against the door it should come out. They can be a B*tch but it will come. Or remove the two bolts holding the roller assembly. Remove it from inside the door. Link to comment Share on other sites More sharing options...
jimoshel Posted August 19, 2013 Share Posted August 19, 2013 To add to the above. Take a hammer and smack it and drive it back into the door. It sounds like the roller is stuck. I suggest you remove it, there's two 10mm bolts holding the roller assembly. Remove them and let the whole thing fall back into the door frame. Retrieve it and see if the roller turns freely. If not, clean and grease, or replace. Don't be surprised to find the mount broken, letting the springs bind and jamming the roller and or the lever. I have welded a couple but it's easier to just replace everything. Is the metal around the two mounting bolts tore up and bent? Another common problem with these things. Link to comment Share on other sites More sharing options...
drase Posted August 20, 2013 Author Share Posted August 20, 2013 I cannot see any metal around the 2 mounting bolts tore up or bent. I'm confused from the posts. Should I try and push the door check back into the door or try and push/pull it out of the door? Link to comment Share on other sites More sharing options...
jimoshel Posted August 20, 2013 Share Posted August 20, 2013 Remove the two bolts and remove the whole thing. More trouble and work but it gives you a chance to inspect it and see what's wrong. Link to comment Share on other sites More sharing options...
