Brakes Losing Pressure
I have noticed as of late that when I come to a stop for about 5 seconds or so my brakes slowly lose pressure and eventually drop to the floor. I replaced my brake booster after finding this out because a friend of mine had a problem with the bladder in his booster and thought that mine my be going out, after replacing the booster and bleeding the brake lines from back to front it is still happening. I am not losing fluid since the level has been staying the same. Could I need to replace my master cylinder or could there be some different underlying problem that I am not noticing? Any help would be appreciated, thank you so much!
