1987 Comanche Fs
1987_MJ
Thinking about selling my 87' shortbox MJ. Located in El Paso Texas. This is a feeler however if a good offer was made I wouldn't have a problem selling it.
Specs:
Originally it was 87, 4.0L 5 speed (BA-10) dana 35 2wd.
Currently
4.0L with 70K on it from a 98XJ
AX15 with external slave from TJ (unknown miles on it but shifts smooth) New clutch with 2K on it.
NP231 from early 90's XJ (unknown miles)
Ford 8.8 rear from explorer. Disk brakes, 31 spline stock shafts, G2 4.56's, Eaton E Locker, Trussed and welded tubes.
HP Dana 30 from 99XJ Motive gear 4.56's, Open, stock shafts.
SOA rear with factory leafs, 4.5" RC coils with 2" spacer. RE adjustable short arms. Currie steering linkage. Custom rear drive shaft.
33x13.5x15 Toyo open countries 50% tread wraped in 15x8 soft 8's 3.75 BS
Body is clean no rust this was a NM vehicle all its life floorboards are solid.
OD green rattle can paint job.
Logans metal products Front winch bumper (no winch)
Truck does have some electrical issues the gauges need new sending units (swapped cluster to get rid of idiot lights)
Interior needs work currently has painted dash/interior pannels. Needs matching door panels (current ones are red leather) also Has a set of 2 Door XJ seats but are not bolted down securely. Mossy oak headliner.
Pics
Reason for selling is I need a more economical DD.
I'd like to get 4,000 for it but make an offer.
Any questions feel free to post on here or PM me. I will upload more up to date pictures in 10 days when I get back to El Paso.
call/text 313-580-9113
  • 3 weeks later...
Archived
