OverlandMJ Posted July 15, 2013 Posted July 15, 2013 I have an 88 4.0l. I went and had the 134 conversion done and had the system vac and topped off. That's all. No condenser or drier done. It blows cool at best. I noticed this morning that when its not on high and the fan isn't loud the ac sounds like a slightly opened valve on a propane bottle. Is this normal. I also don't hear the compressor clutch kicking on and off. I haven't found a leak anywhere. There is die in the system from the charge. Another thing was the tech told me it seems there is a restriction somewhere by what the gauges were showing. Any ideas on what my next chore should be? Thanks in advance! Gary
sloride Posted July 15, 2013 Posted July 15, 2013 Expansion valve maybe? I have been researching doing my conversion and everything I read mentions changing the expansion valve is tops on the list to change. That's not to say that's the cause of your problem, but I would focus my attention on that first. Good luck.
