Ax-15 Popping Out Of Gear
A friend swapped a JY AX-15 into his MJ.
Now when he takes off in first, it pops out of gear, then if you hold it there it stays in gear when you try to take off again.
If you go from Rev to 1st while still rolling it will stay in gear when you take off in 1st.
If you put it into first while you are still rolling before coming to a stop at a light it stays in gear when you take off again.
We drained all the oil, only about a quart in it, and refilled with 30 wt syn, all other gears shift fine.
Bad first gear synchro?
