dasbulliwagen Posted June 30, 2013 Share Posted June 30, 2013 AX4/ AX5 internal and external slave bellhousings are the same part. The internal slave model doesnt have the studs for the external slave or the ball stud for the throw-out, otherwise they are the same. And through comparing part numbers, they use the same clutch disc and pressure plate between the two as well. The driveshaft for a short bed 2.5, AX5, 231 combo will work in a 2.5, AX5, 207 combo. This is assuming that the 207 was only used in the 86 model Comanches. If I'm wrong please let me know. The driveshaft I bought said it was out of an 87, so I assume it was with a 231. I was really worried about this one as I bought the driveshaft 3-4 years ago for my project to convert to 4x4. Measuring the differences in the 2wd and 4wd trans setups comes to almost exactly 12 inches longer for the 4wd one, but measuring the driveshafts I came up that the 2wd one was about 13 1/2 inches longer than the 4wd one I bought. Looking at the 4wd one installed on the lift with the rear at full droop, I have about a full half of spline engagement in the t-case output, so looks like I will be good! All I have left now to finish my 4x4 conversion is re attach exhaust, install crank sensor, install the little bracket that supports the t-case shifter, bleed the clutch master and slave. I also have new U-joints to install, but those will come after I can get this thing moving again. And I guess I need a new speedo cable as the 2wd one is way too short now. Never heard about that being an issue before in reading about other peoples conversions. Oh well. Its also getting new park brake cables as soon as I get the chance as well. Mine have collapsed on themselves rendering the park brake useless. Link to comment Share on other sites More sharing options...
Geonovast Posted June 30, 2013 Share Posted June 30, 2013 When I did my first 4wd conversion, I went from a 2wd AX-4 to a 4wd AX-4(converted to AX-5) and NP 207. I had 11 inches hacked off the DS, and it was a tiny bit too short. About a year later, I swapped in an AX-5/NP231, and the splines engaged a little bit more. :dunno: Link to comment Share on other sites More sharing options...
