Chrome trim above door?
I don't think you can. to take them off you need to pull from the bottom and sorta angle the bottom up and out and it should pop right off...just apply even pressure and if you need to use a screwdriver go ahead, just remember to space out the pressure and not pry too much in 1 place.
