Keith Posted June 22, 2013 Posted June 22, 2013 89 4.0 with 5 speed manual. Fuse block has a 15 amp fuse and it is marked Pass/FL, what does this fuse control? Keeps blowing but I can't find anything that doesn't work when it is blown.
HOrnbrod Posted June 22, 2013 Posted June 22, 2013 Headlamp dimmer switch It's the "Flash to Pass" fuse. The circuit enables you to flash the HI beams when you pull the multifunction switch stalk toward the steering wheel. It's a constant hot circuit that does terminate on the dimmer switch HI contact and it will flash your HI beams even when the headlamps are off. You have a short somewhere between this fuse and dimmer switch if it keeps blowing. Do your headlamp HI beams work normally with the dimmer switch?
