I know the kits says 32 inch tires but I am wondering if 33 12.50 will fit without a lot of rubbing. I will not wheel it hard. Just some light off road when hunting. I have Ravine wheels with a spacer. I think the spacer is 1.5
Thanks for your advise!!
33x12.50 are a problem. At least they were for me when I had 4.5" lift.
33x10.50  will probably work if you have adjustable lower control arms.
Thanks for the quick response. I was afraid of that. I should probably do what the kit says, but I wanted to check first.
Thanks Again.
