Parking Brake Cable
Did they use the same size cables on all 3, 1 front, 2 rear, on the 113 and the 117 inch WB? Or did they use a different size on the rear? I'm ASSuming the front cable would be the same between the two and they made up the difference with the 2 rear ones. Or did they use the same length on both short and long WB?
