Comanche Cherokee Swaps
I know Ive asked before but Ive been told yes and no to will a cherokee front door work on my comanch and will it need mods to make it work because I found a set at a salvage yard with electric window and door locks Id like to put on mine and if not what about just the window guts to replace manual that I have now.  I'm allso looking to put the dash that has gauges not dummy lites if it aint too much trouble. I can't seem to locate cab corner rust repair panels or a full bed liner for the short bed.
From a 4 door cherokee, they fit just fine. 2 door is a no go. Later years I think need updated hinges, not 100% on that. Might need another wiring harness to get the windows and locks to work. Gauge cluster swap is as easy as pulling the old cluster, plugging the new one up and changing the coolant and oil senders.
