boardmanMJ Posted June 7, 2013 Share Posted June 7, 2013 I wanted to do an interior light upgrade to my 2000 XJ classic since a few bulbs burnt out. I did some research and came across a website call superbrightleds.com and I figured I'd try them out. In the XJ (along with the MJ) the interior light bulb calls for the festoon 561LL and the website had them in stick so I ordered them. They came in the mail today and they don't even come close to fitting. Has anyone ever dealt with them before or have any trick to make them work? Just to try them out I wrapped the ends in tin foil to make them work but I really don't want to have to use tin foil for something that is supposed to pop right into place. Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 7, 2013 Share Posted June 7, 2013 They come in four lengths; 1-1/4", 1-3/8", 1-1/2" and 1-3/4". You have to measure your existing bulb and order the same length. Link to comment Share on other sites More sharing options...
boardmanMJ Posted June 7, 2013 Author Share Posted June 7, 2013 The bulbs themselves are the same length. The regular incandescent bulb has the metal caps on the end where as the LED bulb does not. It will pop into place but there is no way for the electrodes to make contact. Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 8, 2013 Share Posted June 8, 2013 Sounds like you got the 4410 series rigid loop festoon lamp. I used the 578 LED bulb - 9 LED festoon lamp.http://www.superbrightleds.com/cat/festoon-series-bulbs/filter/Base,4410,1,5033: Link to comment Share on other sites More sharing options...
boardmanMJ Posted June 8, 2013 Author Share Posted June 8, 2013 Those are exactly what I need. I also have the loop ones you are referring to. I noticed that the light degree angle was only 30 degrees, does that really make much of a difference in brightness? Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 8, 2013 Share Posted June 8, 2013 These were very bright in the MJ fixtures, much brighter than the incandecents. But check the length to make sure they are correct for your application. :thumbsup: Link to comment Share on other sites More sharing options...
92tanMJ Posted June 9, 2013 Share Posted June 9, 2013 There is a huge thread on CF for this I will see if I can find it for ya Edit: http://www.cherokeeforum.com/f2/xj-dash-lights-mod-126507/ Link to comment Share on other sites More sharing options...
