coyote kid Posted May 23, 2013 Share Posted May 23, 2013 replaced my starter .. sounds like a cat bieng strangled ...i heard i have to shim it. how do i do this? Link to comment Share on other sites More sharing options...
87Chief Posted May 25, 2013 Share Posted May 25, 2013 When you took it out, was there anything connected to the hold starter? I had this same thing happen to me and I had to sim mine and it fixed it.. Try auto parts stores, they might have some.. Link to comment Share on other sites More sharing options...
Tempus_Fugit Posted May 25, 2013 Share Posted May 25, 2013 Generally, I put the shims back in that were there when I took it apart. Lacking that, I would add shims until the noise goes away. The older shop manuals had you disconnect the solenoid and manually engage it, then shim until you could get a wire of a given thickness in between the meshed gears. replaced my starter .. sounds like a cat bieng strangled ...i heard i have to shim it. how do i do this? Link to comment Share on other sites More sharing options...
