coyote kid Posted May 21, 2013 Posted May 21, 2013 88 comanche 2.5 went out to start her up stuck the key in turned it ... nothing not even a click...volt gauge is fine double checked with volt meter read 13.5 volts i eventually got it started by arcing a screw driver across the starter solenoid drove it home shut it off and what do you know it starts again was the starter solenoid stuck ? Loose connection ?
cruiser54 Posted May 21, 2013 Posted May 21, 2013 Voltmeter reads battery voltage with the key On, right? What does that voltmeter do when you turn the key to Start?
