coyote kid Posted May 21, 2013 Share Posted May 21, 2013 88 comanche 2.5 went out to start her up stuck the key in turned it ... nothing not even a click...volt gauge is fine double checked with volt meter read 13.5 volts i eventually got it started by arcing a screw driver across the starter solenoid drove it home shut it off and what do you know it starts again was the starter solenoid stuck ? Loose connection ? Link to comment Share on other sites More sharing options...
cruiser54 Posted May 21, 2013 Share Posted May 21, 2013 Voltmeter reads battery voltage with the key On, right? What does that voltmeter do when you turn the key to Start? Link to comment Share on other sites More sharing options...
coyote kid Posted May 21, 2013 Author Share Posted May 21, 2013 drops about 2 volts Link to comment Share on other sites More sharing options...
