coyote kid Posted May 20, 2013 Share Posted May 20, 2013 i have a 88 jeep comanche 2.5 four speed 2wd i want to convert to 4wd i also have a 86 jeep xj with the 2.8 gm 5 speed trans and NV 242 select-trac transfer case do i have everything i need to do the swap to 4wd i will definitly need to shorten the rear drive shaft Link to comment Share on other sites More sharing options...
TheDirtyJeep401 Posted May 20, 2013 Share Posted May 20, 2013 Whats your front axle? Be sure the gearing ratio is the same. Link to comment Share on other sites More sharing options...
coyote kid Posted May 20, 2013 Author Share Posted May 20, 2013 dana 30 yes gearing is the same Link to comment Share on other sites More sharing options...
TheDirtyJeep401 Posted May 20, 2013 Share Posted May 20, 2013 I think you should be good, you might have to change the clutch lines out. Other people will be able to tell you for sure on here. Link to comment Share on other sites More sharing options...
coyote kid Posted May 20, 2013 Author Share Posted May 20, 2013 sweet it looks like most of the mounting points and bolt holes are already there so I'm hoping it will be a pretty simple straight forward swap. Link to comment Share on other sites More sharing options...
