I wanted to know if the Mj and Xj doors are the same because I wanted to buy Warrior Products Front Tube DoorsFor 84-96 Jeep® Cherokee XJ 2 Door and i wanted to know if they would fit
2dr and 4dr doors are different.  '96 and older 4dr doors will swap onto a Comanche with no modifications, 2dr doors are too long.  If you swap the striker then you can swap on the '97+ doors.
As long as you buy the 84-96 ones then they will fit with no real mods besides the hinge as I believe the Warrior ones use a rod to fit into the frame side hinge (been a while since I looked at them though).
